Should I of posted this in the free/wanted section?
Congratulations DBO on reaching 2k posts
Now there's a handy tip. Hmmm makes me think. If you got a piece of that cheap blue plastic tarpaulin from B&Q and sized it correctly, you could use one piece to go through both Caravanstore rails and fall down to make both sides, the bottoms of which could be pegged down. Taking it a stage further, it could have a front too if a t-shaped piece was cut, an you could use a storm pole across the front for the front wall to be passed over before being pegged down. Might be a cheap, light and quick to put up way to make my Caravanstore fully enclosed.dandywarhol wrote:Yep, used gazebo sides Kirsty - and shower curtain rings to secure it to the top Caravanstore rails.
The hems were "wonderwebbed" and brass eyelets fitted to the bottom. They're great and fully enclose the 3 sides
Brings a whole new meaning for "Something for the weekend Sir!"Ian wrote:We are back! But had to leave a day early. If you want to know why, read the full account here:
http://www.igmaynard.co.uk/bongo/tales/midge.htm
There's enough gazebo material to go round the 3 sides (a window around the side and front pole). I use the Caravanstore rafter to make a doorwaymikeonb4c wrote:Now there's a handy tip. Hmmm makes me think. If you got a piece of that cheap blue plastic tarpaulin from B&Q and sized it correctly, you could use one piece to go through both Caravanstore rails and fall down to make both sides, the bottoms of which could be pegged down. Taking it a stage further, it could have a front too if a t-shaped piece was cut, an you could use a storm pole across the front for the front wall to be passed over before being pegged down. Might be a cheap, light and quick to put up way to make my Caravanstore fully enclosed.dandywarhol wrote:Yep, used gazebo sides Kirsty - and shower curtain rings to secure it to the top Caravanstore rails.
Thanks Dandy![]()
Oh Lordy, another DIY project looms
