manual gearbox oil capacity
brookie
Post by brookie » Tue May 20, 2008 10:07 am
Guys,
Can anyone tell me how much oil goes in the manual (2wd) gearbox? I want to change the oil soon.
Thanks!
Mark.
dandywarhol
Re: manual gearbox oil capacity
Post by dandywarhol » Tue May 20, 2008 11:43 am
Long life gear oil (SAE 75W-90) 2.5 litres
The drawing (like a lot of the translated stuff in the manual) is misleading and it looks like the oil level is filled to the top :shock:
Looking at it closer it seems to be showing the gearbox sketch from BELOW the gearbox and "filler plug B" is actually the drain plug on the bottom, in a plate secured by 14 bolts and the filler plug is actually about halfway up the side of the 'box.
Yet another case of bad translation and poor proof reading - one day someone will come a cropper by following dodgy information! :(
brookie
Post by brookie » Tue May 20, 2008 12:28 pm
Great! Thanks Dandy, yep, I'd sussed out the drain and filler, it does take a good look to decide which ones! Still, at least I can do the job now before I go to work.
Cheers,
Mark.
