9 : Engine Coolant Temp
11 : Intake Air Temp
12 : Throttle position sensor
16 : EGR valve position Sensor
60 : Shift Solenoid A
61 : Shift Solenoid B
I thought this would be worth posting since some of these aren't on the fact sheet
The specialist I saw also said several of my codes were probably old and erroneous and that I should briefly disconnect the battery to clear them, then
do a long drive until the fault re-appears, then re-check the codes. Sure enough the faults turns out to be just 60 and 61, still £400+ to fix tho
I also found a page on about.com with fault codes for 1995 Mazda.. http://autorepair.about.com/library/ts/ ... cs-76a.htm
These look right for the Bongo, has anyone had other codes to confirm?
Hope this is useful
