who ever heard of a blocked exhaust ???
bongomaan
Post by bongomaan » Sun May 11, 2008 6:22 pm
just come home on the back of a recovery truck,AA man says blocked middle section never heard of it myself.it just cut out and seemed very warm,nice AA man checked coolant and we tryed it and it ticked over for 20 mins no problem but as soon as you move off it stopped dead.also its leaking coolant from underneath but wasnt this morning and im paronoid about watching temp gauge and it didnt move,so new exhaust and all hoses done before i start it again !!!! oh the shame of it coming home on the back of a truck !!!!!!!!!!
haydn callow
Re: who ever heard of a blocked exhaust ???
Post by haydn callow » Sun May 11, 2008 6:37 pm
Don't belive the "blocked exaust" bit, though it could be the winter pack valve in the exaust stuck shut if you have that option fitted.
I would be much more worried about the lost coolant and where it's from. What was the level in the expansion tank when you checked ?
Do you have a switch low down with a picture of a engine on it. That switches a "block off" valve in the exaust system.
Keep us informed on the outcome.
http://www.coolantalarm.co.uk
Also BMW Clocks
bongomaan
Post by bongomaan » Sun May 11, 2008 6:45 pm
there is not a winter pack fitted and no sign of second battery,ive run diesel vans for years and never heard of this.before it went i did feel the autobox hunting a bit and was going to check atf as soon as i stopped,AA man put his hand over exhaust and it didnt blow his hand away,so he thought it was back box( i have one and planned to fit on my time off this week) he opened up a split in tube behind b/box and still not enough pressure so he said it was blocked exhaust.
bongomaan
Post by bongomaan » Sun May 11, 2008 7:14 pm
as to the coolant level hadn't moved till i undid the cap and it boiled up a bit but man said engine was running hot due to exhaust,no smell of exhaust in xtank ,the other issue was towing,because it would tick over he considered towing with a frame but no technical info on their system,ford ranger can be towed but only 29mph due to autobox,i declined and went for bevertail (struggled on the winch ) any ideas ?
Post by bigdaddycain » Sun May 11, 2008 7:19 pm
I'd definitely request a full lift for transport when broken down bongomaan...You can't be too careful with the autobox.
bongomaan
Post by bongomaan » Thu May 15, 2008 7:06 pm
i removed middle section and backbox and it doesnt seem blocked any ideas anybody ? haydn you said not to believe AA man do you have any idea ? all help appreciated .....
waycar8
Post by waycar8 » Thu May 15, 2008 7:11 pm
i think the winterpack valve is towards the front of the bongo under the passenger seat, in front of the middle section.
when you turn on the winterpack pre warm switch does the revs go up?
haydn callow
Post by haydn callow » Thu May 15, 2008 7:29 pm
Have you tried starting it with the bits of exaust removed.
Also BMW Clocks
haydn callow
Post by haydn callow » Thu May 15, 2008 7:30 pm
waycar8... He hasn't got a winter pack fitted.
Also BMW Clocks
waycar8
Post by waycar8 » Thu May 15, 2008 7:45 pm
haydn callow wrote:waycar8... He hasn't got a winter pack fitted.
:lol: :lol: note to myself...must remember to read all post properly :oops:
have you checked the air intake?, someone reported that they had similar problems to you, cutting out ect and turned out that a carrier bag had got into the air intake and sucked right in
haydn callow
Post by haydn callow » Thu May 15, 2008 7:51 pm
Good point....I remember that....worth checking.
Also BMW Clocks
WISHIHADABONGO
Post by WISHIHADABONGO » Thu May 15, 2008 7:54 pm
I have suffered a blocked exhaust, car seemed under powered and really struggled especially on hills, my cat collapsed and blocked the exhaust
Si
haydn callow
Post by haydn callow » Thu May 15, 2008 8:03 pm
Well !! there you go then. You can have a blocked exaust. Do they all have Cat's??
Also BMW Clocks
bongomaan
Post by bongomaan » Thu May 15, 2008 8:28 pm
will it start without exhaust i thought you needed back pressure or is that petrol engine or am i talking out of my blocked pipe. it can be hard work being a bongo owner but ultimately worthwile .....,,,....
haydn callow
Post by haydn callow » Thu May 15, 2008 8:41 pm
Should run...not very well but noisey.
Also BMW Clocks
