Post
by daveblueozzie » Tue May 06, 2008 8:00 pm
Numberplates
Once your vehicle has been allocated a UK registration number, it must be displayed on front and rear numberplates in accordance with UK requirements. Failure to meet the requirements is an offence attracting a maximum fine of up to £1,000 and in some cases the registration mark may be withdrawn. The police can also issue fixed penalty fines for illegally displayed numberplates and vehicles may also fail the annual vehicle MoT test. It is an offence to alter, rearrange or misrepresent letters or numbers in order to form names or words; e.g. A242 ABC must not be displayed as A242A BC.
For vehicles first registered on after 1 January 1973, the characters must be black, the background must be reflex-reflecting material, white at the front and yellow at the rear. Each number plate shall be permanently and legibly marked in such a position as to be clearly visible when the number plate is fitted to the vehicle, with the following information: (i) the name, trade mark or other means of identification of the maker; (ii) the number of the British Standard, i.e. BS AU 145a.
New or Replacement Plates Fitted from 1 September 2001 must be fitted in accordance with BS AU 145d, and show (i) the number of the BS (i.e. BS AU 145d), (ii) the name trade mark or other means of identification of the manufacturer or component supplier; (iii) name and postcode of the supplying of identification of the manufacturer or component supplier; (iv) name and postcode of the supplying outlet.
Certain imported vehicles may be permitted to display numberplates with smaller characters if:
The vehicle does not have European Community Whole Vehicle Type Approval
And
The vehicle's construction/ design cannot accommodate standard size plates
Specifications for numberplates
Standard size plates
Character Height
79mm
Character Width (except the figure 1 or I)
50mm
Character Stroke
14mm
Space between characters
11mm
Space between groups
33mm
Top, bottom and side margins (minimum)
11mm
Space between vertical lines
19mm
Smaller size plates (for certain imported vehicles)
Character Height
64mm
44mm
Character Stroke
10mm
10mm
thanks to trev for this info from another post.
Lost without my Bongo.
