Seat Belts too long.
Oggy Bongo
I notice that the seat belts latch is fixed to quite a long length of belt between the latch and the fixing bolt.
Does any one know if there is a replacement available that with a shorter length of material and maintain the integrity of the seat belt?
- Attachments
- IMG_1016.JPG (99.83 KiB) Viewed 2916 times
Re: Seat Belts too long.
Why are they too long? Are they fouling a child seat?
I think the split seat belt tags are longer than the bench seat tags, but they may not be compatible - there is a slight difference on the male ends of some bongo belts, but I am not sure if it age related or seat related.
sajseven
Yes... have noticed that the actual latches seem to go all the way up the side of my stomach. An odd feeling, yes, but I bet I'll get used to it.
alexxb
Here was my solution - worked for me and my wife was happy with it.... Kids still ok.
take seatbelt catch, push through seat - wrap once around under seat bar and push back through - hey presto - shorter seatbelts that work on car seats.
Easily solved - just get a big stomach like mine!sajseven wrote:Yes... have noticed that the actual latches seem to go all the way up the side of my stomach. An odd feeling, yes, but I bet I'll get used to it.
sajseven
Hard when you're this old. Look at the age in my profile!
I went to school with some who managed it
sajseven
I'll be keeping my lips sealing about that one...
- brorabongo
alexxb wrote:Here was my solution - worked for me and my wife was happy with it.... Kids still ok.
Thats what we did, more about it here:-
http://www.igmaynard.co.uk/bongo/forum/ ... it=+buckle
I had my seat belt stalks swapped with ones from the front seats of another vehicle (another bongo I think). Its the easiest solution and very easily done. Mike at Wheelquick did it for me. Needed it done for child seats.
northerntaff
Hi Oggy
If you get down and look under the bench seats in the back, you'll see the webbing for the seat belt buckle is attached to a kida clamp with a point facing the front of the van. If you loosen the bolt and turn it round so the point is facing the back, it naturally moves more of the webbing under the seat and therefore leaves less above !
We did this on one of ours so that the buckle didn't 'crunch' on our childseat.
hope this helps
hope this helps
I employed the 'wrap around the bar' method too ! Had my fears about safety, but eventually convinced myself that in a high speed crash, if the bar let go it would act as two lesser jolts on the kiddy seat (rather than one large jolt). That seems like a better option that the buckle getting squished and letting go !!
Oggy Bongo
Thanks for this everyone.
It is buckle crunch and there are a couple of options that sound like they will do just fine.
Nice one and thank you
Oggy
White over silver, 'S' Reg AFT with mini tourer conversion.
Oggy
Swapping the base part of the seatbelt is really the easiest way -as the top part is standard and loads ofplaces have seat belt bits going free. Mine were wwapped in minutes and it didnt even cost me anything.
