Rough running
Mandy W
Rough running
Post by Mandy W » Thu Apr 10, 2008 9:58 pm
Does your Bogo run rough at anything more than tickover with great plumes of white smoke from the exhaust, have very little power and struggles to change gear? :(
Then check and clean your injector pump banjo fuel filter!!!
I was convinced the problem was a faulty injector or two but decided to check the simple things in the fuel system first, lo and behold the fine guaze filter was all but blocked - leading to fuel starvation and all those problems. Now, thanks to the advise in the forum, my Freeda is back on song as good as ever :D .
Peg leg Pete
Re: Rough running
Post by Peg leg Pete » Thu Apr 10, 2008 10:00 pm
Good news :wink: Warm welcome :)
Image Pete
Mandy W
Re: Rough running
Post by Mandy W » Thu Apr 10, 2008 10:17 pm
Thanks Pete.
Peg leg Pete
Re: Rough running
Post by Peg leg Pete » Thu Apr 10, 2008 10:18 pm
Have you a location to put in your profile please
Image Pete
Re: Rough running
Post by mikeonb4c » Thu Apr 10, 2008 11:01 pm
Good news Mandy W and welcome (if we've not welcomed you before). Very satisfying result 8)
Bongoplod
Re: Rough running
Post by Bongoplod » Thu Apr 10, 2008 11:06 pm
Yes,glad youre sorted,and Welcome
Brian
brorabongo
Re: Rough running
Post by brorabongo » Thu Apr 10, 2008 11:17 pm
=D> Well done Mandy, Glad it was as simple as that. It's amazing how the strainer can get so clogged up, even though the fuel has to go through a filter first. :?
All the best, oh and welcome to the forum. :D
ボンゴの激怒 pictures
coco bongo
Re: Rough running
Post by coco bongo » Thu Apr 10, 2008 11:38 pm
Welcome Mandy :D That too is a job ive got to tackle just to be sure. Mines a bit rough on start up at times.
Enjoy the forum.
