I've had to order a Radiator as mine is seeping at the top where the plastic meets the metal lugs, which are not locking over the plastic lip, like they are elsewhere on the rad.
So I will need to top up, and bleed (really looking forward to that!!) once I replaced the rad. (thanks Harry for the fact sheet)
Just now my coolant is a bright Green, so I believe I will need the same again. Does anyone know which brand uses Green?
Also from the fact sheet I see there is a mention of a gear oil hose? Is that for automatics only? (mines a manual) As all I can see on my original rad is.....top hose to engine, top hose to tank, and bottom hose to engine.
Cheers.
