EGR Removal
smac02
EGR Removal
Post by smac02 » Sat Mar 29, 2008 1:22 pm
I've read everything I think I need to know about the EGR system and decided Im going to remove the whole thing. Can someone tell me where I can obtain the kit of blanks and the blank for the exhaust? I believe the name I need is Nick Skidmore. Anyone help further
Steve Mc :shock:
haydn callow
Post by haydn callow » Sat Mar 29, 2008 1:40 pm
Just PM him....I belive his user name is nick skidmore
http://www.coolantalarm.co.uk
Also BMW Clocks
Post by missfixit70 » Sat Mar 29, 2008 2:36 pm
Not sure if he's making the kits anymore or if he's still about on the forum, but it's worth a try, very satisfying to remove all that useless pipework :D . I think a few people have done the job by cutting off & welding up the 36mm threaded connection on the turbo. If you have a hunt around on the old threads you may find what thread size it is & be able to make or get a plug made up if Nick isn't doing them anymore. The other option is the Allans kit which i think allows partial removal?
dobby
Post by dobby » Sat Mar 29, 2008 3:04 pm
I used Allans kit, it's two blanking plates that you slide into place to block the EGR off. Mildly fiddly/easy job
bongomaan
Re: EGR Removal
Post by bongomaan » Thu Apr 03, 2008 12:45 am
after my beloved failed to start monday morning,ordered glowplugs(£28 ebay) and blanking plates (£12 allens) fitted tuesday night,like a new vehicle ,started on the button with no smoke,money well spent,hopefully save some money on fuel too,three hours to fit,but beware to be careful removing small black pipe (bellow green valve ) on large air intake pipe ,i wasnt and snappped the bugger (its very brittle ! ) and had to resort to the dreaded super gloop but ok up to now...... pps to undoo one of the twelve mill bolts to fit egr plates i removed plate at the rear of the engine compartment made things a lot easier.
ccrobins
Re: EGR Removal
Post by ccrobins » Thu Apr 03, 2008 9:14 am
where can i get allans kit from - obviously allan i know but where is he ?
dobby
Re: EGR Removal
Post by dobby » Thu Apr 03, 2008 9:36 am
