unidentified noise!
alectroll
unidentified noise!
Post by alectroll » Thu Mar 27, 2008 12:09 pm
Right here we go again, Deep Breath!!! When i get to 65-70mph i get a noise which i can only liken to driving over the rumble strip at the side of the road or listening to my neighbour using a hammer drill on the other side of the wall (as he tends to do quite often to my annoyance!!!!) The noise disappears if i let off the throttle or if i accelerate, spoke to the local garage and he reckons its a whell bearing on its way out. Is this correct or is he just trying to get yet more money out of me, advice please!!
Harry
Post by Harry » Thu Mar 27, 2008 12:12 pm
Sounds like either the all too regular problem with wheel balance....many (most?) bongos do this at some time.
H 8)
http://watcherswildlife.co.uk
alectroll
Post by alectroll » Thu Mar 27, 2008 12:24 pm
ta, so i just need to nip in and get the wheel's rebalanced then and see if that improves it?
Post by missfixit70 » Thu Mar 27, 2008 12:31 pm
Get the tracking done too while you're there, cheapest things to check first :wink: Between -1 to 7mm toe in I think, the dodgy translation from the Japanese manual seems to have caused some confusion by being read as 1.7mm, not that it makes a huge difference as that figure is within range. Some argue for setting them parallel, which again is still within range. :D
alectroll
Post by alectroll » Thu Mar 27, 2008 12:32 pm
ok will do, many thanks.
Post by mikeonb4c » Thu Mar 27, 2008 1:29 pm
ust admit it doesn't sound especially like wheel imbalance to me but I guess it can take several forms (I only ever notice the sort that manifests itself as shaking on the steering wheel - always at 65-70 mph, weird!)
Veg_Ian
Post by Veg_Ian » Thu Mar 27, 2008 1:33 pm
Yeah it does Mike. Mine's always done it at about 80mph. It's not so bad with the new tyres, wheel balance and tracking but still there.
Harry
Post by Harry » Thu Mar 27, 2008 3:01 pm
If that doesn't alter it...then get the joints/bearings checked on your propshafts..
alectroll
Post by alectroll » Thu Mar 27, 2008 3:59 pm
tracking done, was well out!!! drives better but the noise still seems to be there but not to as great an extent.
brorabongo
Post by brorabongo » Thu Mar 27, 2008 5:11 pm
I had a noise a bit like that a while back and the problem was that the two front tyres had flat spots, more than one. If fact the tyre was more like a fifty pence piece. It was also noticable, (but not half as loud) with the windows down and travelling at a slow speed.
As mentioned on this thread:-
http://www.igmaynard.co.uk/bongo/forum/ ... re&start=0
The picture that was missing-
ボンゴの激怒 pictures
lizard
Post by lizard » Thu Mar 27, 2008 9:08 pm
brorabongo wrote:I had a noise a bit like that a while back and the problem was that the two front tyres had flat spots, more than one. If fact the tyre was more like a fifty pence piece. It was also noticable, (but not half as loud) with the windows down and travelling at a slow speed.
There is a lesson to be learned here, don't use 50p pieces for tyres :lol:
F Zappa
daveblueozzie
Post by daveblueozzie » Thu Mar 27, 2008 9:24 pm
i had new tyres and alloys fitted last year, when travelling at about 69.9 mph :lol: i got a wheel shudder, so got my tyres rebalanced, it still did the same ,had them redone again different garage (all four) it still shudders at 70 mph. it only does it at that speed if i go over 70 by mistake :wink: it disappears .
Lost without my Bongo.
Post by bigdaddycain » Thu Mar 27, 2008 9:30 pm
daveblueozzie wrote: it still shudders at 70 mph. it only does it at that speed if i go over 70 by mistake :wink: it disappears .
Not that you ever Do stray over 70 of course though dave..... :lol:
Electroll? Do you have aftermarket alloys fitted? Are any of the spigot rings missing/squashed etc...?
Does wheel rotation make any difference, or are you running different sized tyres front to rear?
The Great Pretender
Post by The Great Pretender » Thu Mar 27, 2008 11:55 pm
Bloody ell tecky questions. :shock:
I had this problem one of my tyres didnt have a flat spot but was out of round. :wink:
coco bongo
Post by coco bongo » Fri Mar 28, 2008 12:35 am
Ha!, some of you have done what i have, i get the shaking on the steering wheel at 65-70mph. Went through all the motions as you do, balancing, tracking. Shake is still there slightly, but not as bad as when i first got it.
A new tyre seemed to shut it up a bit, ive got marshall on the front, and continental vancos on the back. The tyre that was causing all the severe shaking was "egg shaped" as the tyre fitter said.
It's a shame that it shakes at 70, seems like a common thing
