Cyclinder head leaking slightly???
Ramsey
Post by Ramsey » Thu Mar 27, 2008 12:04 pm
Hi all,
I have noticed for a while now that when I check my oil there is a bit of oil around the back few nuts on the cyclinder head. I cleaned it off last time but its back again? Im not overheating or losing excessive oil, everything seems fine I just doubt that oil should be leaking from these nuts. It seems to be from the nuts rather than the gasket area as the oil residue is on the top of the head above the gasket. Could it be the nuts arent sealed properly, should I be really worried????
Any advice would be gratefully received.
Many Thanks
Ramsey.
Veg_Ian
Post by Veg_Ian » Thu Mar 27, 2008 12:09 pm
Probably the rocker top gasket is leaking a tad. If it's any consolation mine does it as well. I don't consider it bad enough to finding a replacement just yet.
Post by missfixit70 » Thu Mar 27, 2008 12:15 pm
Mine too, wouldn't worry too much, if it bothers you, then change it, may just be slack nuts? a couple of mine were a bit slack, just tightened them up a tad, made quite a difference.
Post by mikeonb4c » Thu Mar 27, 2008 1:36 pm
missfixit70 wrote:Mine too, wouldn't worry too much, if it bothers you, then change it, may just be slack nuts? a couple of mine were a bit slack, just tightened them up a tad, made quite a difference.
I had exacly the same experience and cure as Kirsty (missf.) Since I cleaned off the oil with gunk, no more has appeared. I gently tightened the rocker cover (not cylinder head - that's a completely different issue) nuts in the area just a little. I recall being told of old you have to be careful with allow rocker covers like the Bongo (in my day the old BMC engines had pressed steel covers and alloy was novel) as you can crack them if you tighten them unevenly and/or overtighten them. Also, unless they are tightened in the right sequence and with balanced tightening they.....wait for it......leak! Hmmmmm :roll:
Post by missfixit70 » Thu Mar 27, 2008 6:58 pm
Turbo may be forcing a small amount of oil out of the air inlet manifold joint/s too, hardly noticeable but gets blown everywhere :roll:
lizard
Post by lizard » Thu Mar 27, 2008 8:07 pm
Oooer Matron :lol:
F Zappa
Ramsey
Post by Ramsey » Thu Mar 27, 2008 9:44 pm
As ever you lot are awesome! Thanks for your very prompt replies, reassuring stuff. I take it the rocker is the bit at the topof the engine?
brorabongo
Post by brorabongo » Thu Mar 27, 2008 9:51 pm
I noticed today whilst doing my glowplugs that the whole of the engine block, and only the block, looks a bit wet. Does look more like oil than water. I'll will be keeping an eye on my levels more regular then usual. 8-[
ボンゴの激怒 pictures
