getting into the engine
Im struggling to get into the engine, I have unclipped the two clips on the seat but cannot work out how to move the chair to get into the engine bay .
Can anyone shed any light to help with this task that should be really easy - yes i feel really stupid please help!
Arran
Arran
Re: getting into the engine
There are three clips.....arran wrote:Hi,
Arran
Two accessible from the front edge of the seat and one that's only accessible once you've removed the centre console. Remove the ash tray and look under the mat at the back of the centre console (or inside the cubby box if you're posh) and you'll find two plastic wing-nuts.
Have fun!
Dave
Most of us have had that problem first time around...and my garage still struggles after 2.5 years.
First remove the centre console...you will find two round 'butterfly' type thingies...one under the ashtray and one in the middle of the large square recess. Undo these and lift off the centre console.
Next undo three clips per side...two on the front of each seat and one that links the seat to the centre section which you'e just uncovered.
Now tilt the back of the seat forward then lift the front of the seat base...the whole thing should then tilt back.
If you have problems tilting the seat back, check the footrests arn't in the way.
good luck
H
good luck
H
I'd forgotten that Ozric had done that one...MountainGoat wrote:Just watch this video, all is explained.
http://www.youtube.com/watch?v=XyeHJUCXNVs
Well done
- The Great Pretender
I found that one to Harry but where is the real one?Harry wrote:Immediately after the first time I bought a van with this configuration I pulled into a garage to fuel up and check the oil.
Bonnet up...no engine...so I rang the dealer and he said not to worry...there was a spare engine between the front seats![]()
H
Sitting in the middle of my van GPThe Great Pretender wrote:I found that one to Harry but where is the real one?Harry wrote:Immediately after the first time I bought a van with this configuration I pulled into a garage to fuel up and check the oil.
H
