Spotted this 50w / 12v lamp produced by Sealey Tools .Apparently used to detect ''leaks in cooling systems '' with use of fluorescent dye . Model VS602 with free special offer of a set of light enhancing specs .£39 incl vat
OK, a tad much for a home mechanic but do garages use them and do they work ?
ULTRAVIOLET COOLANT LEAK DETECTOR
Origo bio stove - no Bongo!
- Bongonaut
Sealey advertise it specifically for testing cooling systems The above is a direct quote from their sales brochure. I presume that they envisage it being used as a 'there and then ' check when something has gone wrong - - but - - - if the dye could be left safely in the system and if it did not deteriorate over time then a quick once over with the light could alert the owner to a problem .No idea how practical this would be .
I am not an expert , just spotted a possible application for us - - - -
They will probably appear on Ebay after this posting as overpriced 'kits' and somone will clean up - - - hey ho
