Due to spending many hours trying to find a fault that caused all my external lights to work apart from the headlights, i thought i'd let you all know a cheap way of replacing the two relays on the inner wing (passenger side) that illuminate all the external lights. These can be replaced using mazda 626 items which are a straight swap for the bongo items
due to the position of these relays, the rubber jackets that are supposed to protect them actually fill with water & cause the relays to malfunction!!
