Cooling fans
- The Great Pretender
I think this one will be personal preference, and if my mechanic says it wouldnt hurt as long as it's not forgotten, I will go with him.
Beside's it's only one more thing to think about. Do we forget to use signals properly?, or does a pilot forget to turn the landing lights on?. Not when you get used to it.
- dandywarhol
Going by the number of times I forget to cancel my bike's indicators I wouldn't trust myself having to remember anything - NURSE! Have I had my tea yetcoco bongo wrote:I think this one will be personal preference, and if my mechanic says it wouldnt hurt as long as it's not forgotten, I will go with him.
Tried Dandys tip to check the rad fan. First - when I put the aircon on (heating fan turned on too) then the rad fan works and from the bonnet its very clear from the noise that it is on!
I ran the engine at 2000rpm for 5 mins and not a great deal of movement on the temp gauge( mason fitted). I ran for another 4 min and by then the needle was about 80% across the range. Mason buzzer set at 4 and not sounding - rad fan not on.
What do I deduce from this :-
a) rad fan needs much higher engine temp to come on
or
b) sensor from engine temp to rad fan may not be functioning
I could keep on running at 2000 rpm until it gets really hot but I dont want to take a risk. Does anyone know where the sensor and connectors are that actuate the fan according to engine temp?
Ron
or
Ron
Does anyone actually monitor the water temp with an acurate gauge?
The reason for asking is that the heat exchanger on my veg oil conversion is not reaching the expected temp. So today I fitted a gauge on the outlet hose and was very suprised.
The thermostat was open at under 40c and the Bongo gauge was at 11 oclock by 45c and never moved.
- dandywarhol
Sorry folks - a bit of miss info in my previous post re. temp gauge reading.
After it had warmed up, I ran mine tonight (6 deg. C outside) for around 7/8 minutes at 2500 rpm and the gauge reached up to about 2 needle thicknesses before the last mark on the gauge before the fans came on.
The workshop manual says the cooling fans come in at 108 deg C and the scavenger fan at 180 deg. C
- dandywarhol
coco bongo wrote:Blimey! scavvy fan at 180![]()
Well the override is next Saturday's job along with an oil change![]()
Will let you know how it turns out, i will try and post photo's if i remember to take my camera. Bang goes my weekend lie in
Remember 180c isnt water temp it is air temp, how much do you think the exhaust manifold contributes to it?
But I must admit if the Bongo is stationary and the main fans are on it would make sense if the scavenge was on to.
Cheers Mike, it's your idea after all in all it's simplicity. All credit goes to you and Dandy of course.mikeonb4c wrote:
Watching this thread with great interest Coco - good luck
Will give it a damn good bench test on saturday 22nd, and post in the evening on my findings.
That'll burn up my £20 worth of diesel a bit
