Towing a car
quinnw
Towing a car
Post by quinnw » Wed Mar 05, 2008 2:15 pm
I've seen a lot of motorhomes tow a small car for de-camping, so:
a) i presume the Bongo would have enough torque to tow something small (C1, 107, etc.)
b) anyone know of a suitable device? I have seen permanent fixtures to the bumper / chassis of tow car Image but would like a temporary option (like the AA / RAC use).
c) Any (known) legal issues?
crazy uncle gray g
Post by crazy uncle gray g » Wed Mar 05, 2008 3:03 pm
:roll: Here you go for starters, not cheap but totally illegal it would seem, if the laws where fully applied :arrow:
http://www.trailers.co.uk Then click car transporters, then car dolly.
Hope this helps, CrAzY
Last edited by crazy uncle gray g on Wed Mar 05, 2008 8:10 pm, edited 2 times in total.
cheers! party on dudes.
Mr Halibut
Post by Mr Halibut » Wed Mar 05, 2008 3:53 pm
A C1 is something like 900kg kerb weight? I tow a Caravan that is between 950 and 1340kg (depending on if its empty or fully loaded) and considering the wind resistance of a huge white slab it tows it with ease.
The disadvantage is you have to keep to the legal max towing speeds rather then fly past at 85 like some of these huge campers do and upset my caravan and leave it wriggling about.
Mr Halibut
Post by Mr Halibut » Wed Mar 05, 2008 4:05 pm
Alternatively a lighter vehicle would be the ariel Atom weighing in at less than 500kg!
Not to mention 0-60 in 3 seconds
paul9
Post by paul9 » Wed Mar 05, 2008 5:33 pm
these are strong enough to tow most cars.
http://cgi.ebay.co.uk/A-FRAME-TOWING-DO ... dZViewItem
trevd01
Re: Towing a car
Post by trevd01 » Wed Mar 05, 2008 5:47 pm
quinnw wrote:I've seen a lot of motorhomes tow a small car for de-camping, so:
This is a wind up, right?
The idea of towing a car behind a motorhome is because once you have arrived on holiday, your motorhome is too big to park when you go to town etc.
The advantage of the Bongo is that it is a campervan - smaller than most campervans in fact - and will go anywhere a car will go (other than multi-storey carparks).
Get a Range Rover and tow the Bongo! :twisted:
scanner
Post by scanner » Wed Mar 05, 2008 6:44 pm
crazy uncle gray g wrote::roll: Here you go for starters, not cheap but totally legal :arrow:
There is a lot of debate about this is the motorhome forums and the legality of any towing arrangement
where all 4 wheels are not off the ground is dubious - UNLESS - it is for the purpose of recovery
after an accident or breakdown when completely different regulations apply.
The general opinion is that "A" frames where the car is towed on all 4 wheels are totally illegal except for recovery purposes.
The dolly as shown is really getting into the big grey area between "A" frames and full trailers.
Note that they say "Supplied to RAC and other leading companies" - for recovery use??
tedpippa
towing car
Post by tedpippa » Wed Mar 05, 2008 7:57 pm
Hi Quinnw,
Firstly i must agree that you don't need to tow a car because of the size of the Bongo ,secondly if you do the car is then classed as a trailer and trailer towing rules apply i.e if the trailer weighs more than 750kg it MUST HAVE OPERATIONAL BRAKES ,if not it is ILLEGAL TO TOW. We used to have a 33ft American ant towed with an a frame that worked the brakes but this cost over £800! yes it can be done but at a cost. As they say- the choice is yours but personally we wouldn't bother
regards
Dave
crazy uncle gray g
Post by crazy uncle gray g » Wed Mar 05, 2008 8:00 pm
:roll: Just found this, interesting reading :arrow:
http://www.ukcampsite.co.uk/articles/view.asp?id=18
scanner
Post by scanner » Wed Mar 05, 2008 8:05 pm
The situation regarding enforcement could change at any time and, as a result, the only safe way to transport another vehicle behind a motorhome is on a car transporter trailer. Play safe! Don’t take the risk!
This is the bit that matters.
bighairypict
Re: Towing a car
Post by bighairypict » Wed Mar 05, 2008 8:08 pm
trevd01 wrote: Get a Range Rover and tow the Bongo! :twisted:
Or a caravan :twisted: :twisted:
check some of these postings
http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=19208
crazy uncle gray g
Post by crazy uncle gray g » Wed Mar 05, 2008 8:09 pm
Cheers scanner, you will notice I have edited in RED my first post :wink:
mister munkey
Post by mister munkey » Wed Mar 05, 2008 8:33 pm
If I were to tow anything, I'd like it to be a second Bongo behind mine.
Maybe a nice contrasting white one.
8)
scanner
Post by scanner » Wed Mar 05, 2008 8:39 pm
With all these Bongos getting written off at the front I'm seriously thinking about buying one, chopping the front off and making a matching trailer.
All I need is the bit out of the middle of a bendy bus and I could have a Bendy Bongo.
Ohh the choices of where to put the awning and being able to just unhitch the back bit when going off for the day.
mister munkey
Post by mister munkey » Wed Mar 05, 2008 8:46 pm
scanner wrote:With all these Bongos getting written off at the front I'm seriously thinking about buying one, chopping the front off and making a matching trailer.
Genius!!
