Wheel Bearing Replacement
Geoff Drucquer
Post by Geoff Drucquer » Sun Mar 02, 2008 11:18 pm
Could someone please help. I need to change a front wheel bearing. Is this a job for a garage or has anyone do it before? i.e. are presses needed to get the old one out of the hub and the new one in ?
robdrinky
wheel
Post by robdrinky » Sun Mar 02, 2008 11:43 pm
have not done wheel bearings but recently ours(P reg) needed new cv joint boots and i was unable to get the hub apart.
i gave up and booked it in to my local garage-they eventually took the drive shaft out for the diff end to do it.
you may not have the same trouble though-guess it comes down to what tools and time you have.
best of luck :wink:
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
Geoff Drucquer
Post by Geoff Drucquer » Mon Mar 03, 2008 2:00 pm
Thanks it looks like a garage job then unless anyone has done it themselves
Veg_Ian
Post by Veg_Ian » Mon Mar 03, 2008 2:17 pm
As I haven't done this myself Geoff, I can't say for certain but looking at the exploded diagram it would appear that the outer wheel bearing is a press fit. To 'drift' it out would need access from the back of the steering knuckle and if troublesome could require removal of the steering knuckle to gain access. Not a 5 minute job but if you have the time and inclination it should be do-able without having to take it into a garage. Unless of course someone who is more in the know can counter that......
