Cooling fans
coco bongo
Cooling fans
Post by coco bongo » Mon Feb 25, 2008 11:46 am
Does anyone know how to test the fans to see if they are working properly?
I have not heard them kicking in for a long time, and have just had new head fitted etc.
Would it also be worth getting the fan sensors replaced?, Cos im still going through a process of elimination on the cooling side.
Before my head went i heard the scavenger fans working, obviously was very hot to make them come on. But now not a sausage!.
Temperature gauge is at 11 o clock, but is a bit smoky and chuggy on start up.
Cheers for any help :wink:
Darren.
dandywarhol
Post by dandywarhol » Mon Feb 25, 2008 12:00 pm
The actual cooling fan operation can simply be checked by turning on the a/c, otherwise the sendor is a 2 terminal one on the head under the driver's seat - about midway along the head if I remember correctly.
helen&tony
fans
Post by helen&tony » Mon Feb 25, 2008 12:06 pm
The sensor for the scavenger fan is that little black device by the handbrake with 2 wires going to it . You'll see it if you remove the handbrake console. Lift the drivers seat, and you will see the sensor poking down into the engine bay. I think that if you unclip the plug from the sensor, you can short the connections in the plug with a bit of wire to make the fan work. The fan only works when the engine is very hot....most people find it hardly ever switches on
helen&tony
fans
Post by helen&tony » Mon Feb 25, 2008 12:08 pm
you beat me to it Dandy
coco bongo
Post by coco bongo » Mon Feb 25, 2008 12:19 pm
cheers u guys!! will check it out.
Re: fans
Post by mikeonb4c » Mon Feb 25, 2008 3:11 pm
helen&tony wrote:Hi
It'd be an interesting mod to provide it with a manual over-ride. Gives it some exercise, checks it is still OK (sensor apart), and even on an averagely hot day there are times when I wouldn't mind cooling the radiator next ot me (at other times it's lovely and cosy) :roll:
On the list it goes 8)
dandywarhol
Post by dandywarhol » Mon Feb 25, 2008 3:46 pm
Just put a switch in place of the sensor on top of the engine cover - you could fit it on the centre consule. You could even go the full bling and have a blue LED in it :wink:
Post by mikeonb4c » Mon Feb 25, 2008 6:56 pm
I know - a doddle. Must do it :)
Post by bigdaddycain » Mon Feb 25, 2008 7:08 pm
I'll consider the mod if it means i can have more LEDS! :lol:.
Seriously, thats not a bad idea mike,the manual overide is a nice touch,even if its just to test the fan every now and again.
Post by mikeonb4c » Tue Feb 26, 2008 1:00 am
bigdaddycain wrote:I'll consider the mod if it means i can have more LEDS! :lol:.
..and should be so simple. Why didn't we think of it before. Still keep the sensor control, just have a rocker switch for over-ride. Put it on the dash next to the rear fan switch control in the blank there. will I ever get out again - aaaarrrrggghhhh :?
coco bongo
Post by coco bongo » Tue Feb 26, 2008 11:44 am
And when you're stuck in traffic in the summer, would also be an advantage.
Cos if these fans only come on when it is red hot, the damage is being done to the rest of it in the meantime. Manual override and keeping sensor, sounds like a good plan 8)
And just think you might be doing your Bongo a great favour,and extending component life maybe.
Another job for it this year methinks.
Cheers guys
Post by mikeonb4c » Tue Feb 26, 2008 2:32 pm
Spot on Coco. It's going on my list 8)
lizard
Post by lizard » Tue Feb 26, 2008 7:45 pm
Not only could you fit a switch with an led, you could fit a buzzer so you could hear when it is energised. :wink:
If the motor was seized/burnt/worn out , there would be know way of knowing if it were actually working without having a look. The fuse may still be ok.
Can it be heard running from the cab :?:
F Zappa
dandywarhol
Post by dandywarhol » Tue Feb 26, 2008 10:09 pm
I think you guys should apply for design engineers jobs with Mazda cos it's obvious that the current designers have no idea what parameters to set sensors to.................... 8) :lol:
Post by mikeonb4c » Tue Feb 26, 2008 10:47 pm
dandywarhol wrote:I think you guys should apply for design engineers jobs with Mazda cos it's obvious that the current designers have no idea what parameters to set sensors to.................... 8) :lol:
Oh yes they did. Tokyo parameters. Only we don't get Tokyo parameters here and don't like getting even a little bit hot. Anyway, it's another gadget/switch to add to the growing array - love it :lol: :lol: :lol:
