andyh
Post
by andyh » Thu Feb 21, 2008 10:00 pm
Changed me battery - had this bit of plastic left over and cannot for the life of me work out where it came from... not the plug...
You've Been Bongod
Post
by You've Been Bongod » Thu Feb 21, 2008 10:03 pm
that'll be the cover that sits behind battery and heater vents me thinks
you've been bongod
robdrinky
Post
by robdrinky » Thu Feb 21, 2008 10:09 pm
on ours that part attaches to the intake scoop that feeds the heater matrix.
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
Peg leg Pete
Post
by Peg leg Pete » Thu Feb 21, 2008 10:28 pm
The intake it sits behind is the air intake to the engine I believe
Pete
MountainGoat
Post
by MountainGoat » Thu Feb 21, 2008 10:49 pm
You will find two small holes at the back of the plastic air intake into which this plastic sheild is clipped using plastic retaining studs. These studs seem to get easily broken and suitable replacements are hard to find. Mine has been put back with studs from Halfruds which do not hold it firmly in place as before so it rattles around a bit now. Will probablly come loose again soon.
behavedave
Post
by behavedave » Fri Feb 22, 2008 10:16 pm
Check out the 4th post in
this thread.
You can see it there in front of the black battery
aitch
- Location: in a place far, far away, well Somerset for now!!!
Post
by aitch » Fri Feb 22, 2008 10:46 pm
i wish i knew how to do that as it is so clever.
looks right to me but how do you put in those links??????
baffled in somerset ....
aitch
Post
by aitch » Fri Feb 22, 2008 10:59 pm
Post
by missfixit70 » Fri Feb 22, 2008 11:21 pm
Took me a few goes to get it right the first time, still have to check how to do it, I don't understand it, I just follow the destructions
aitch
Post
by aitch » Fri Feb 22, 2008 11:40 pm
think i'm still destructing!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post
by bigdaddycain » Fri Feb 22, 2008 11:49 pm
Iv'e just spent 45 minutes trying it aitch, pm myself a pic from photobucket.... no chance mate! = in the first bracket, then
word after last bracket.... nope, doesn't work for me (no suprise there then
andyh
Post
by andyh » Sat Feb 23, 2008 12:20 am
Thanks behavedave - you cant beat a picture... all is clear...
Now I'm fretting on inserting links - I feel so inadequate...
