how do you remove alloy wheel centres.
paul gange
Post by paul gange » Tue Feb 19, 2008 5:09 pm
hello its me again when i bought my bongo it came with a nice set of alloy wheels ,a thought has just struck me sods law if i get a puncture in the dark how do i get the sodden wheel of?.thewheels have flush fitting centre plates and show no indents to get at the wheel nuts.your thoughts please.
scanner
Post by scanner » Tue Feb 19, 2008 5:17 pm
Often the cap is held on with an allen screw or a hidden clip and you should have a little thing like a bottle opener that you insert in a slot to flick the cover off.
Post by Muzorewa » Tue Feb 19, 2008 6:08 pm
If it's like mine, the centre is in two pieces - the centre bit has two slots visible at the edge to pry with a screwdriver. This flies off and then the other (outer) bit of the centre falls into the road.
These pics may clarify.......
paul gange
alloy wheel removall
Post by paul gange » Wed Feb 20, 2008 9:51 am
many thanks for your suggestions ill give it a try.
pippin
Post by pippin » Wed Feb 20, 2008 8:10 pm
If you still haven't got them off, just find one of your local scroats (aka thieving bastards) who will no doubt oblige in the blink of an eye.
