Ignition switch wiring help anyone ?
Thanks for looking, I am in the throws of alarm fitting, and wondered if anyone has the colour info for Acc, On, and Start at the key switch my cable to multi plug is as tight as a bow string so checking a little difficult, Just run up my wiring diag from the shop up and its showing corrupt ? any help would be great....many thanks Rich
- The Great Pretender
If I was trying to determine the wiring, I would first of all find the main feed to the ignition switch.
Then I would disconnect the big connector and apply a voltage to the contact on the plug, on the ignition switch side.
With the big connector still disconnected, I could then determine which wire went live in what position of the key. This would determine, what does what.
Hope that helps in some way?
Karl
Karl
Brilliantly simple Karl, like a knife through butter, but have you done a risk assessment of kneeling down, head under steering wheel? can you do it with your hard hat on, safety glasses, knee pads, exclusion zone?roosteruk wrote:If I was trying to determine the wiring, I would first of all find the main feed to the ignition switch.
Karl
oooh thers never a dull moment on this web site .. i bought a wiring diagram off the club shop in the summer to sort a problem out. Put the disk away after use in the racking and come to run it up and it could not read the disk..? i am not sure on the construction but i think a veg based oil is used ? to look at the disk , not a scratch or blemish, but its sort of run between the top coat of the disk, if you press your finger on it it can be pushed around the disk between the laminations ? very strange ?? hence no wiring diagram otherwise i could have nailed it in 10 seconds flat ... looks like my multimeter got to come out.... anyway thanks again for all your help Rich
