Just a thought, is it wise/necessary to have a return to the diesel tank? is that overcomplicating it & possibly contaminating the diesel with veg oil when the system purges?[/quote]
Watch this space..................
I realise that Dandy, but what is now the diesel tank, I am assuming would become the veg oil tank & a smaller tank would be added for the dieseldandywarhol wrote:The pump has a return to the tank anyway Kirsty. I'm looking forward to the next stage too GP
As you can see the copper pipes are connecting fixed points, vibration will ony wear through anything if it is rubbing on something else. Also vibration will work harden copper.flashgordon69 wrote:Hi guys
The reason that they say not to use copper pipe for these sort of things is due to the fact that copper is soft and prolonged vibration will wear thru it!
Thanks mate.Big Rich wrote:Hi The Great Pretender you have got to be a plumber with such neat pipe work!I live over in Chesterfield but do loads of work in Wigan...! on the lamberhead ind estate about once a month or so ....also good clear photos thanks Rich
