FITTING OF MASON ALARM
Hi All,
I have just recieved my mason alarm and was wondering if you can point me in the direction of some detailed instructions on how to fit it. I am investing in the alarms (coolant alarm next) as we had a close call when the steel pipe running under the drivers side sprung a leak. I think we got away without serious problems but I am keeping a close eye on the coolant levels for any loss. We were recovered through Autoaid at a cost of£110.00 which was reimbursed within 2 days of us subbmitting the claim. The whole family love the bongo but she is starting to make me worry about future costs and also for using her on our long holiday journeys.
Thanks to you all for any help,
Mike.
Mike.
First, tilt the steering wheel down as far as it will go, using the lever on the bottom of the steering column. To get the instrument cluster out, there are four screws -- two facing down at the top, and two at the bottom. Once you have these out you should be able to pull out the grey plastic to reveal the whole instrument cluster. Be careful when pulling -- you could have wires to unattach from the fog light. I don't remember whether there are more screws to remove the cluster, but you need to get it out to attach the Mason alarm wires as per instructions. It's best to unattach the cluster from its wires for easy access. When connecting the Mason alarm wires, don't overtighten the three screws -- the circuit board is pretty flimsy. I stuck the unit to some switch blanks to the left of the steering wheel. Put it all back together, and off you go. You will need to set the alarm between 3 and 5.
- missfixit70
You choose at what temp they go off, a bit of trial & error, but set them around 4.5 seems to be about right.
Mine went off after accelerating up a steep hill, towing a large folding caravan, then stopping at a layby, turning the engine off almost instantly. When I got back in a few minutes later, the mason alarm went off when I turned on the ignition, showing 108 degrees on the digital temp guage I fitted.
I turned the mason up slightly from where it was at about 4.3 to just above 4.5 & the alarm stopped, as soon as the engine was running, temp dropped right back to 100 ish, couldn't get it much above that again, but then I wasn't pushing it as I wasn't sure of the caravan's brakes
Excellent bit of electrickery, great to actually see the temp gauge have a bit of movement as well as knowing it'll shout at you if there's a problem
Along with the other essential (IMO) Coolant Alarm, I worry much less about overheating issues
missfixit70 wrote: Mine went off after accelerating up a steep hill, towing a large folding caravan, then stopping at a layby, turning the engine off almost instantly.
