leaking oil filter
leaking oil filter
Since changeing the oil and filter about a month ago the bongo is leaking oil from what looks like the filter. The filter is tight but not over tight (ie bit more than hand tight).
I seem to remember a thread regarding dodgy filters that leaked but I cant find it.
Any suggetions?
Any suggetions?
Between last April and June there was a dodgy batch of Comline filters where the seal came away from the casing. There were also reports of some other cheap brands, probably made at the same Taiwan factory, having the same problems. It sounds like you have a duff one, and you should change it immediately before it dumps your oil completely. If it is part of the dodgy batch, it fails on start up immediately after installation.
Hmm, Could be one of the dodgy filters that Ian mentioned then... A lot of peeps forget to smear the filter you see Harpo,that's why i asked.
I'd try tightening it a bit more Harpo... You may have more luck tightening it when the engine is stone cold.
- Peg leg Pete
Had another look at the filter and topped up the oil this weekend.
Looks like the O ring on the filter is too small and does not protrude enough to make an effective seal.
I have done as BDC suggested and tightened all up when cold, also used a strap to REALLY tighten. Topped the oil right up. All seems ok at the mo but will check again regulary to see if loseing oil. If that is the case then will replace the filter.
Thanks for all the help.
Harpo
Harpo
- dandywarhol
- haydn callow
