Mason alarm settings
I don't know how many users of this forum have installed Mason alarms -- but it would be very interesting to know what people set their alarms at. I have set mine at just over 4.5. The only time I ever hear a peep out of it is when I drive for a while at 65-70mph, then turn the engine off for a few minutes. When I restart the engine the alarm makes a few peeps that stop within a few seconds of the engine running.
When I had the alarm set at 4, it would sometimes peep a little bit when the engine was being worked hard without going fast. It was fine on the motorway -- I assume because there was plenty of air hitting the radiator.
The Mason alarm should be useful for keeping an eye on the condition of the cooling system -- but this means establishing what setting a bongo will typically run at without the alarm going off.
i have mine set at 4.5,sometimes gives a few beeps if going up long steep hills,also will beep if engine switched off for a few minites after a long run ,then re started,when start off driving soon goes off again,also gives a beep when ignition first switched on,quite normal and is an indication its working.
- daveblueozzie
Mine's set at 4.5 too... I've only had my mason alarm fitted for a week or so, but something i have noticed is,when pottering around town,up to 30(ish) mph, then stop at lights, move away...etc ,etc... My temp gauge hovers roughly at around the 1 o clock mark... Do a steady 65 mph, on the motorway on flattish ground, it stays nearer the 1.30 mark?
I'd have thought it'd be the other way round?
Ambient temp seems to make no difference to the running temp on the motorway either....
Has anybody else noticed similar traits?
My temp gauge also stays at about the 1 o'clock position in town, or stuck behind tractors etc., and settles at about 1:30 on dual carriageways, perhaps very sightly higher when worked hard at lower speeds (It's hard to tell). It takes quite a while to get all the way to 1 o'clock from cold -- at least 7 or 8 miles. After it gets warmed up to 1 o'clock it does not vary very much -- I expected more variation as a function of driving conditions. But I have only run it for 2 or 3 hours at a go since fitting the alarm, and haven't done a long road trip.
- dandywarhol
I've set two at 5, one at 4.5 and one at 3. My own one is set to 5 and the needle gets to about 85% towards red when the fans cut in.
curiously the alarm didn't sound when i was bleeding the cooling system tonight after fitting a water pump
