Reversing lights
bighairypict
Reversing lights
Post by bighairypict » Sun Jan 13, 2008 12:15 am
My reversing lights seem very dim, probably OK to warn anyone behind but not nearly as bright as I would like for seeing where I'm going in the rearview mirror.
Anyone ever had this problem?
Anyone ever tried fitting brighter bulbs?
brorabongo
Post by brorabongo » Sun Jan 13, 2008 12:20 am
ボンゴの激怒 pictures
platty345
Post by platty345 » Sun Jan 13, 2008 12:53 am
Think we all ave the same prob, Just be carefull.
Post by missfixit70 » Sun Jan 13, 2008 1:08 am
Use the foglight, just don't forget to turn it off again. I intend to add some reversing lights probably underbody type idea, probably along the sides aswell, it's quite a long way down the joblist though :?
bighairypict
Post by bighairypict » Sun Jan 13, 2008 1:24 am
thanks, team =D>
This morning Mrs Pict complained about how far out I had left the Bongo when I came home last night :?
Did the numberplate LEDs do the trick Brora? They might get a person in a bit of trouble with Mr Plod if he was using flash-proof plates :wink: any thoughts?
Until I get to a more suitable solution I will be continuing to use Kirsty's fog lamp trick :idea: . It does a far better job of illuminating the back of the van.
brorabongo
Post by brorabongo » Mon Jan 14, 2008 2:17 am
Led's do help a bit, as in I can notice the road lit up in the rear mount mirror, but it's rather dim. I've got 4 led lamps in just now, I did try it with 9 leds, but one fitting started to smoke. :shock: I think it was due to a poor connection. :? I'm planning to try again, and pull out the pins on the led, for a better grip in the fitting. [-o< I will let you know how it goes.
I too, have used the rear fog for extra light. It does help, and like missfixit70, one day I might add an extra light or two. :-k I Have not found a flush fitting clear light/lens like the red fog. Bigdaddycain has a nice pair! :oops: Check out the "don't click here" at the bottom of one of his posts. :wink:
ボンゴの激怒 pictures
Post by bigdaddycain » Mon Jan 14, 2008 2:49 am
Yo Brora!...I simply CANNOT find this light(s) any more...
I did a search on e-bay, then went through my e-bay purchases one by one, (i'd had a pm asking where they were from),but find it...i could not :evil:
It doesn't help that the item description dissapears after 90 days, which means that you have to second guess the type of seller you are trying to look up.... :roll:
I originally put something like "flush clear" in the e-bay search bar... Or something like that....
