A query about fords....
Post by bigdaddycain » Sat Jan 05, 2008 12:31 am
There are plenty that will argue that if the exhaust tip is sitting lower than the level of the water,then the exhaust will fill with water and the engine will stall...This need not be the case, if the speed of the bow wave is matched,the level of the swirling water at the back of the vehicle lowers significantly,plus, if a low gear is held, and revs kept up, the back pressure coming out of the exhaust will blow away most of the water from the exhaust tip, providing the entire pipe isnt completely submerged.
DemonAV
Post by DemonAV » Wed Jan 09, 2008 2:43 pm
Just one photo on this topic
Russian Mazda Friendee Club
http://www.mazdafriendee.ru
platty345
Post by platty345 » Wed Jan 09, 2008 2:53 pm
WOW, Did it make it out? :D
andyfb78
Post by andyfb78 » Wed Jan 09, 2008 4:11 pm
the engine is one issue, and as stated with correct technique, no issues.
but check the various breather heights (axle, gearbox etc), i have no idea where they are ont bongo, but when adapting a landie to wade beyond 700mm the breathers need raising too.
Post by mikeonb4c » Wed Jan 09, 2008 6:49 pm
Excellent DemonAV - your usual impeccable standard of contribution and picture. 8)
bighairypict
Post by bighairypict » Thu Jan 10, 2008 11:34 pm
did it today :shock: (not quite to the extent of DemonAV)
No choice :? (all the roads home were flooded)
No Problem :wink:
