Parking pole/stick bulb replacement
Do you know how to replace the bulb in the front passenger-side parking guide pole? I have unscrewed the whole pole from the bumper and it has revealed (left behind) a pair of stiff wires with nothing on the end. Is the bulb inside the stick? Is it an LED? Does the transparent plastic lens come off? Where can I get a new bulb? many thanks
I presume yours is the non telescopic type?
If so. then, yes, the lens does come off, but is probably very tight. Careful you don't shatter it.
There is a pea bulb in a holder but if you only have two wires it sounds as though this is missing. I suggest you go to Maplins and buy an LED, but make sure you get the polarity correct before re-assembly and insulate the wires!.
Good luck.
Good luck.
