Mazda ISO Leads
tog21
Mazda ISO Leads
Post by tog21 » Sun Jan 06, 2008 5:37 pm
Hi again,
Another question from a new Freda owner I`m afraid :)
I am picking up a Ford Freda this week, and I have bought a DVD player for it. Will the Mazda ISO connectors you see on eBay / Halfords be the same for the Freda or will I need Ford ones?
Again, thanks in advance guys :)
Neil
dandywarhol
Post by dandywarhol » Sun Jan 06, 2008 6:14 pm
Mazda ones should do just fine - I seem to remember they were quoted as 121 adaptors.
moonshine
Post by moonshine » Sun Jan 06, 2008 6:22 pm
As far as I am aware, the only difference between the Mazda and the Ford versions is the badges. The wiring should be identical. The adapter I used when I connected my radio was a PC2-10-4, from Halfords.
waycar8
Post by waycar8 » Sun Jan 06, 2008 6:25 pm
if you want the iso lead, the ones from halfords were £15 when i bought mine, but after i bought it i found that bongobits did them for £11 they use to sell them for around £7.50
http://www.bongobits.com/Main.asp?PageN ... Product=49
You've Been Bongod
mazda iso leads
Post by You've Been Bongod » Sun Jan 06, 2008 6:41 pm
hi neil qestion for you
why do you need a iso adapter ?
unless your bongo /freda has had wireing chopped you dont need them as most stereos now days come with one
all you need to do is swap yellow wire ( memory wire ) and red (live ) into each others connecter and hey presto you have memory on your stereo
you've been bongod
tog21
Re: mazda iso leads
Post by tog21 » Sun Jan 06, 2008 7:35 pm
You've Been Bongod wrote:hi neil qestion for you
you've been bongod
Well, I`m not 100% sure whats behind the stereo thats in it at the moment as I pick it up this week.
It has an aftermarket stereo in it at the moment, so dont know what to expect really.
Thanks for the replies guys. Great as usual :)
You've Been Bongod
mazda iso leads
Post by You've Been Bongod » Sun Jan 06, 2008 8:03 pm
neil you should be ok as many aftermarket stereo's are a straight fit
if i can be of anymore help dont hesitate to contact me pm or email \:D/
you've been bongod
madmile
Re: mazda iso leads
Post by madmile » Sun Jan 06, 2008 8:22 pm
You've Been Bongod wrote:neil you should be ok as many aftermarket stereo's are a straight fit
you've been bongod
Sorry guys, but if you have a standard mazda or ford wiring harness it will not fit a standard uk radio with ISO connections - hence the need to buy one.
The one you need is a PC10-4 (I think) - it should state all Mazda except 121 (sorry Dandy).
dandywarhol
Post by dandywarhol » Sun Jan 06, 2008 10:11 pm
:oops: - I thought it was something to do with the 121 :oops:
scanner
Post by scanner » Sun Jan 06, 2008 10:27 pm
dandywarhol wrote::oops: - I thought it was something to do with the 121 :oops:
The reason being that a 121 is/was a rebadged Ford Fiesta and it was made in Dagenham, so had ISO instead of Japanese connectors.
