Torque setting for front wheel bearing nut..Any ideas?!
Hi there,
Does anyone know the Torque setting for the front wheel bearing nut? I'd like to service the front disc bearings.
Also, are there any specific steps when tightening?
Thanks for your help!!
- Tribal Elder
When I recently replaced my cv gators I put new hub nuts on and to tighten them I used a 35mm socket and a 3 foot breaker bar to loosen and tighten the nuts. They where tightened up as tight as I could get them , then with the wheel back on the floor and someone pressing the brake pedal tightened it up again - yes that tight
don`t forget the hubnuts are one shot items so must be replaced with new ones when you take the old ones off. Hope this helps .
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
Hub nuts
I should do your best to find out what the correct torque is for the hub nut as 'over' tightening can be as bad as 'under' tightening. Sorry I can't help with the correct figure but hopefully someone with the workshop manual will let you know.
- dandywarhol
Front hub nut torque
Thanks for that info Dandy, I'm sure it will noted for future use by us all although it seems such a wide range.
In English it is 52 to 70 foot/lbs.
- dandywarhol
Torque
I must have been still asleep when I calculated that (stupid girl) - oops me wheels are just about to fall off...............................
pic with Torque setting. Nut #1
dandywarhol absolutely right
Russian Mazda Friendee Club
http://www.mazdafriendee.ru
