fiamma pro c
cliffy the climber
fiamma pro c
Post by cliffy the climber » Wed Dec 19, 2007 10:53 pm
im after a bike rack for the bongo..and fancy the fiamma ones...
i like the idea of the bolt on ones..ive alrweady hacked holes in the bongo for ducting and cable so a few more wont hurt...
my question is...are people using the long bolt on one..like 80-150 cm
or the small one which i think is about 40-50 cm..
the top bolts on the long one would bolt where the tailgate curves as far as i can see..so i am guessing the small one....
....thanks cliffy
p.s to all that answered my last post thanks..the heater is fitted and running....
Foz.Foz
Post by Foz.Foz » Tue Jan 01, 2008 3:16 pm
Only just seen this post..... :roll:
I ended up chopping the long bolts ( you should be supplied with 8 if I remember correctly ). Let us know how you get on ( if you haven't fitted it already.
the-bongo-mongo
Post by the-bongo-mongo » Tue Jan 01, 2008 3:19 pm
80-150 cm ! :lol: is that not mm...sorry for being a pedant.... :wink: just use larger washers to save any panel work getting bent/pulled....and make sure they are well tightened to save holes from widening....
