What am i looking for
Bongoplod
Re: WD 40??
Post by Bongoplod » Fri Dec 28, 2007 5:10 pm
Socket Set Sue wrote:Is it April Fools day tomorrow? :?
Nope,i cant get get that one either :oops:
Brian
Post by bigdaddycain » Fri Dec 28, 2007 5:32 pm
I think vanmaneri.....er, sorry, socket set sue may be having a dig at my over simplified terminology???
I was just trying to keep it in laymans terms for a genuine query from a non mechanically minded person.
The belts drying out is indicative of a worn perished rubber belt in need of replacement,or failiure may be imminent.
The wd40 trick temporarily moistens the belt to a degree that the chirping sound dissapears, as the belt dries and returns to its perished brittle state,so will the chirping return.
If the chirping noise continues,it could suggest a fault with the alternator,or perhaps re-torquing of the pulleys,or pulley bearings may need attention.
The wd40 spraying on the belts iliminates the possibility of it being a more serious inherent fault.
susan
Post by susan » Fri Dec 28, 2007 7:13 pm
Many thanks for your help it seemed to work a treat :D :D .As for the laymans terms it was very helpfull FOR ME, as i really do try to have a go if i know what to look for,but it gets my goat with this flaming site when you ask for help,you get some people giving such UNHELPFULL remarks :!: :!: :x :x :x :x :x :x if you cant help then keep your remarks to yourself :!:Big daddy cain i will pm you in future ok.
Post by bigdaddycain » Fri Dec 28, 2007 7:18 pm
Ok sue...no probs :wink:
tigs
Post by tigs » Fri Dec 28, 2007 7:20 pm
susan wrote:Many thanks for your help it seemed to work a treat :D :D .As for the laymans terms it was very helpfull FOR ME, as i really do try to have a go if i know what to look for,but it gets my goat with this flaming site when you ask for help,you get some people giving such UNHELPFULL remarks :!: :!: :x :x :x :x :x :x if you cant help then keep your remarks to yourself :!:Big daddy cain i will pm you in future ok.
:shock: reminds me of someone but cant quite remember who
tomsk
Post by tomsk » Sat Dec 29, 2007 12:56 am
Dear Susan
My local shop sold me Millers Oils, Diesel Power Plus, and it now starts first time, no problems whatsoever, runs great.
Pop it in the fuel tank on filling up, I have had other additives, but non have performed as good as this.
Regards
Tomsk
susan
Post by susan » Sat Dec 29, 2007 12:58 pm
Ok will give that a go to :)
Socket Set Sue
April Fools Day?
Post by Socket Set Sue » Sun Dec 30, 2007 1:25 am
Sorry I could not reply earlier but I had a long haul job on today.
If I was told to spray WD40 onto my fan belts I would think it was a joke. BD is correct to a point with his synopsis but not with the method of determining the fault. Now if BD had have said spray water on the fan belts I would have agreed, if the sound had stopped - usually very quickly, say 30 seconds the sound will re-apear then it could be the belts drying out is indicative of a worn perished rubber belt in need of replacement,or failure may be imminent.
Unfortunately a squeaky belt can not only mean a worn out belt it can also mean that the alignment of the pulleys may have changed slightly, due to wear and tear or even a nut or a pulley coming loose so it really needs a good visual check to determine the reason for the squeak. (Best done with the engine OFF)
Remember we are not only talking about just the two belts driving the alternator and water pump but the other belts concerned with driving the vacuum pump for the brakes and power steering.
I suppose there is even a chance the squeak could eminate from the timing belt.
So as you can see my thoughts are 'why contaminate the drive belts with a spray lubricant when we are told to keep all drive belts free of oils and contaminants, yes it will cure the squeak but it will not cure the problem if it hides the squeak for a period of time. Water will do exactly the same but safer and will dry out very quickly without contaminating the belts.'
I hope you find these remarks helpful and it helps you rectify your squeaky belts.
There is a fact sheet for changing the belts, you may need it. :)
Off to bed now, night.
Socket Set Sue
WD40 n Squeaky Belts
Post by Socket Set Sue » Sun Dec 30, 2007 6:06 pm
I thought there would have been a reply to this by now, or is the silence an acceptance of good practice? :wink:
daveblueozzie
Post by daveblueozzie » Sun Dec 30, 2007 6:15 pm
Not necessarily ,not all of us sit in front of a pc/laptop all day.
Lost without my Bongo.
Socket Set Sue
Busy
Post by Socket Set Sue » Sun Dec 30, 2007 6:43 pm
Nor me, just turned on as the veg were simmering away nicely, the beef was 'resting', and the Yorkshire Puds were just ready to go in, must go dinners ready to be served.
So whats it to be, WD40 or good old fashioned water???? :D
Post by bigdaddycain » Mon Dec 31, 2007 12:41 am
Hi "socket set sue", As i have seen trained mechanics using wd40 on squeaky belts, i assumed it was an accepted practice?
I deliberately ommited the possibility of the misaligned pulleys scenario,in the hope that you would repeat the same diagnosis as you had previously posted when you went under the name of vanmanerik.
Its verbatim of vme's post from last year...
Either you are quoting he, or you are he.... :wink:
The Great Pretender
Post by The Great Pretender » Mon Dec 31, 2007 12:47 am
Sue, you shouldn't use water, fish pee in it. :shock: :shock: :shock:
Post by bigdaddycain » Mon Dec 31, 2007 12:50 am
:lol: :lol: :lol:
daveblueozzie
Re: WD40 n Squeaky Belts
Post by daveblueozzie » Mon Dec 31, 2007 12:57 am
Socket Set Sue wrote:I thought there would have been a reply to this by now :wink:
SILENCE :shock: NO REPLY TO BDC.....Either you are quoting he, or you are he....
