Hope it is just the gasket. Want to do it myself but can anyone reccomend a bongo friendly mechanic in the Wolves/Telford area? It may be worth getting a quote.
Sam
whenever a head needs replacing its always a good idea to replace the radiator and thermostat at the same time.patmckenna wrote:Hi BongoMTBer,
I agree with Mike - it does sound like a problem with air in the system. I take it Flippa's hoses were replaced by the same guys who fitted the new cylinder head? I would also be tempted to worry about the state of the radiator. If you read the (many) posts on overheating problems, members often end up replacing the rad ...
Hope it sorts out. Double check all the hose connections in the morning.
Pat
After having my head replaced & system bled, it took a few days for the system to settle down & find its own level.BongoMTBer wrote:
Took it for another 20 mins of driving and opened up again, another small gurgle and level drop. 0.5 litre top up back to full.
Is this normal after a full hose and head replacment, or have I still got a leak?
