I will let you all know how it goes.
Isn't that more or less the principle that Haydn's kit usesThe Great Pretender wrote:How about 2 probes set to the low level in expansion tank using the water to make a circuit when ignition is on. Use that to hold a relay open. If water level falls below probes, circuit opens, relay makes providing power to buzzer ect.
Im with you, I make as mutch as I can because im a tight gitBongoMTBer wrote:I think you have misunderstood me. I am not looking to produce a 'product', I am just having a play on my Bongo and was going to post my findings for a DIY soloution.
However, if you don't want me to share my experiences......
As was said above, this probably isn't a good idea because you will set up an electrolysis process which will degrade the coolant and destroy the electrodes. Worst case you start generating hydrogen and oxygen gas in your cooling system which you definitely don't want.The Great Pretender wrote:Im with you, I make as mutch as I can because im a tight gitBongoMTBer wrote:I think you have misunderstood me. I am not looking to produce a 'product', I am just having a play on my Bongo and was going to post my findings for a DIY soloution.
However, if you don't want me to share my experiences......![]()
This is what I was thinking of.
http://i72.photobucket.com/albums/i187/ ... /relay.jpg
