This is the fiirst time that I have entered the forum.
Ive had by 95 Black Bongo since May
Normal problems !! Water leaks, drag links etc.
Any way back to the gearbox clutch problem
I had same sort of problem dificult to engage gear etc
I had a new clutch fitted by the supplier of bongo
PRESURE PLATE SPRINGS WERE SHOT IE. RATTELED AND WORN
The clutch is not ajustabe ( all hydrolic )
If you put your head under the drivers side you will see the slave cylinder
Get some washers and get underneath pull the actuator arm back out of the clutch folk and put some washers on it ( ie as spacers )
this will give you more travel
HOPE THIS HELPS
