Leaking hose
xjr1300
Leaking hose
Post by xjr1300 » Tue Nov 27, 2007 3:33 pm
Hi to everyone,
Took the Bongo and four mates to NEC Bike Show yesterday and the van ran great but this morning saw leaking water under her. Looks to be a split hose which comes from the centre of the engine on the drivers side, underneath the seat and twists down to another connection. Anyone know what it is and can I get a replacement ?
Thanks in anticipation, Bill
haydn callow
Post by haydn callow » Tue Nov 27, 2007 3:38 pm
Top hose "engine to metal pipe" Jal have them cheap.
http://www.coolantalarm.co.uk
Also BMW Clocks
haydn callow
Post by haydn callow » Tue Nov 27, 2007 3:43 pm
See lushprojects around the engine, diesel, cooling system
Part No 15-186 HOSE WATER
Also BMW Clocks
haydn callow
Post by haydn callow » Tue Nov 27, 2007 3:44 pm
Make sure you bleed it properly after replacing.. Loads of info on here or PM me
Also BMW Clocks
xjr1300
Leaking hose
Post by xjr1300 » Tue Nov 27, 2007 3:59 pm
Hi again,
Thanks for the swift replies. Got to fetch grandkids from school but will be back online shortly.
Bill
Socket Set Sue
Split Hose
Post by Socket Set Sue » Tue Nov 27, 2007 4:39 pm
Hi Bill, From your description I think you will find this is the pipe that runs from just above the starter motor to the rear heater inlet, its part no. is 61-213 Part Name Hose no. 3.
The pipe Haydn has suggested is the main outlet pipe from the head to the radiator top hose.
Copy and paste the url below into your browsers address bar to see a schematic.
http://www.lushprojects.com\bongoparts\pages\6125A Rear heating components.html
Hope this helps.
Dabs
Post by Dabs » Tue Nov 27, 2007 6:12 pm
http://www.igmaynard.co.uk/bongo/forum/ ... highlight=
Id agree with socket set sue it will be the one to the rear heater I had a problem with it a short while ago got my new hose from Bongobits.
Dabs
Socket Set Sue
Leaky hose
Post by Socket Set Sue » Tue Nov 27, 2007 6:47 pm
Snap, same thing happened to me, not easy to spot either, was a fine pinhole only visible when engine was hot and running.
xjr1300
Leaking hose
Post by xjr1300 » Tue Nov 27, 2007 7:18 pm
Hi All,
Bongobits it is. Thanks to everyone for your help. What a Forum.
Never alone with a Bongo !
Cheers Folk, Bill
