Van Tyres vs Car Tyres
I was reading through a post on Tyres, and someone mentioned fitting `Van` tyres, presumably as opposed to car tyres. To be honest I`d never heard of them. What`s the difference? WOuld they help stiffen up a wobbly ride? Thanks, Surfnut
- brorabongo
'Real' van tyres have very square shoulders and often very chunky (hence noisy) tread patterns. Have a look at a newish big van - Sprinter, Ducato or Master - or a motorhome based on any of them.
There are van tyres and van tyres, though. Many people rate Conti Vancos highly on Bongos.
But there are alternatives which can give you the high load rating you need, with a car shape and tread pattern. The Yokohamas fitted to our Bongo are an example - see this topic for a picture:
http://www.igmaynard.co.uk/bongo/forum/ ... hama+tyres
They are not the cheapest, but a cheaper alternative many people like are Nangkangs - see this topic for a picture:
http://www.igmaynard.co.uk/bongo/forum/ ... kang+tyres
But tyre pressure make a huge difference - we run at 36/40, which improves the feel enormously. Many of us believe the quoted 'Japanese' pressures are far too low for UK tyres, speeds and road conditions.
Tyres
Went to ATS this weekend - had a nail in the tyre Had it patched.
And they have a promotion on at present buy 3 tyres get the 4th free. The manufacturers they have this deal on are Michelin, Continental, and Avon.
Did have some cheaper ones, not in the deal, Nanook for £65 per wheel. The Conti Vanco's were £78 which worked out as the cheaper option.
Surely the load rating is the critical one not the plies? As long as the Bongo load rating is met (or exceeded) then it should be okay. I am surprised that no-one has mentioned road holding as that was the reason for me using car type tyres. Van tyres are often hard rubber compounds for high mileage which does not give as good a grip. Multiple plies can also give a stiffer and harsher ride leading to extra noise and less "feel".
I'm with you there Bumbly1 - I test drove several Bongos and what I was looking for - and eventually found - was a Bongo that felt better to ride in than a van (and I did my time van driving some years back - great, but the wife woudn't buy into it). I'm not even that keen on the 'firm' ride of the modern VWs and a Bongo with the right tyres on - even though narrow wheelbase, high CofG, and tendency to roll - is the kind of ride I like (no rude comments please)
- dandywarhol
