Strange noise from pulley area,on closer inspection the bottom inner pulley,(which drives the two belts for water pump etc),has come unnattached from the outer pulley,it is rubber mounted apparently,how has this happened?any ideas?
I have sourced a relacement,but need to know how this pulley comes off?Is it just the giant nut in the middle of the pulley that holds it on?if so is this an easy job,or is it hours of swearing,scraped knuckles and lying underneath my bongo!!
Lucky I investigated the noise b4 pulley sheared off completely and stopped driving the water pump!
Any advice graetly appreciated!
Cheers,Hammond
