track rod ends. I.m a Bongo Virgin
Gizmo
Post by Gizmo » Thu Oct 25, 2007 8:16 pm
Help I bought a P reg last month and had it serviced yesterday the guy who serviced said it needed a lot of work -shit!! I rang the garage I got the bongo from and asked if the following were covered under the warrenty he said no- but challenged the following fault " Track rod ends damaged and leaking-both need changing" the garage I bought from said they can't leak -who do I believe???
Post by francophile1947 » Thu Oct 25, 2007 8:27 pm
Track rods ends cannot leak - they are packed with grease and don't get anywhere near hot enough to melt it. The only time anything would show is if the rubber covers had disintegrated (highly unlikely!!)
Try another garage because that is a blatant lie that even the newest apprentice would know about.
mister munkey
Post by mister munkey » Thu Oct 25, 2007 8:31 pm
Interested to see what else they found. . .
Worn Flayrod Spiggotts perhaps.
A splayed Flange Treadle maybe. . .
Post by francophile1947 » Thu Oct 25, 2007 8:33 pm
mister munkey wrote:Interested to see what else they found. . .
You've been there yourself have you? :lol: :lol: :lol: :lol: :lol:
dandywarhol
Post by dandywarhol » Thu Oct 25, 2007 8:37 pm
Got to disagree there franco - they will leak grease if the rubber is split...............
Post by francophile1947 » Thu Oct 25, 2007 8:43 pm
dandywarhol wrote:Got to disagree there franco - they will leak grease if the rubber is split...............
Agreed Dandy, but it's got to be quite a bad split and is unlikely to happen to both at the same time. I've had to replace them on several vehicles over the years and never had more than the merest trace of grease when the rubber has perished.
I'm wondering if they really meant CV gaiters?
Baldeagle
mot
Post by Baldeagle » Thu Oct 25, 2007 9:47 pm
The worst problem is the nut behind the wheel !!!!!!!!!??????????????
