I,ve just received a MPH replacement dial for my Bongo.
I can,t find a thread with fitting advice so I wonder if a kind BONGOTECH could talk me through the procedure please.
regards,
N415 PTL
Replacement speedo dial
This is metioned a few times on the forum. If you read all the way through the topic on this link, it should sort you out.
http://www.igmaynard.co.uk/bongo/forum/ ... d1c2#73540
- brorabongo
Would they be the same to fit as these?
http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=14641
as they are easy enough to fit, without removing the needles
Thanks for the info so far,BUT, what I need are step by step instructions
starting with "Pick up the Phillips scredriver"!!
If it will break I will break it!!
In eager anticipation,
Steve
Steve
replacing speedometer dial
Thanks for the offer Lee,but I live in St Ives Cornwall!
Why didnt I read this post yesterday...doh fitted it all together in the house put it all back turned on the ignition and nought to 20 in 0 sec...bugger
so then tried with it in place, pulled centre cap of needle and the soddin counter weights dropped behind the facia, retrieved these and dropped one down the side of the drivers seat, neccesitating removal of the seat.
apart from that and pulling the wire out of the rear fog light spade, a doddle....havent tried it yet though, could be
