Flashing ABS and Airbag Lights
JD
Post by JD » Wed Oct 10, 2007 12:39 pm
I have a strange problem with my Freda - after driving for about 20 minutes or more the Airbag and ABS lights begin to flash. They seem to follow a sequence of six flashes and then a pause and six flashes and a pause and so on. They don't always do this especially if it's only a short trip ?? It's a mystery...... any ideas greatly appreciated.
Nibs
ABS
Post by Nibs » Wed Oct 10, 2007 8:26 pm
:D 8) :lol: : Hi, had a similar problem this year with ABS light and was given advice that its usually down to poor insulation at the rear of the instrument cluster. Did just that removed the pod dusted the back reconnected and hey presto no bother since.
Cheers Paul
Ralph
Post by Ralph » Wed Oct 10, 2007 8:34 pm
Had the same on a Ford some time back just
took the abs relays out cleaned the connections and
put em back fixed.
Don't know were they are on the Bongo though.
richrich
Post by richrich » Wed Oct 10, 2007 8:46 pm
Hi. Does your horn work. If not, maybe its the wiring in the steering wheel, although unlikely if ABS is also flashing :?
JD
Post by JD » Thu Oct 11, 2007 12:39 pm
Thanks all - the horn does work OK so will check the insulation etc.
Craig
Post by Craig » Thu Oct 11, 2007 12:57 pm
Had exactly the same thing happen only two days ago, ignored it carried on driving, radio stopped, windows stopped. arrived at destination, she wouldnt re start. The alternater had packed in. just in time for the eastern counties meet! :x
