Cheers DaveDave Mason wrote:Wayne: There should be a self-test bip from the Mason alarm when you turn the key. I expect that's it. Once you know what it is most owners find it re-assuring rather than annoying.
Bongo Mason alarms are currently available on http://www.townace.plus.com/ie/ietemga2.htm but I'm having difficulty making them fast enough!
Agreed. One component could be altered to bring down that 90% and I'm happy to supply instructions to any customer who wants to do that themselves, or to do it for you, free of charge, if you arrange it with me and post the alarm box back to me. The problem with going that route is that you then can't make simple comparisons between Bongos, it would depend whether you have a version 1 or version 2 Mason alarm.Grahame at work wrote: ... In preference I would like to have seen this working at 50% to 80% as hitting 90% at times does not leave much room to show an 'abnormal' tempeature. Having said that it is still way better than having it stuck at the '11 o'clock' position ...
