Throttle pedal
Throttle pedal
Hi All
Can any one tell me what the round plastic disc shaped
thing under the throttle pedal does? on mine it's marked
lock/unlock or some such, turning it allows you to take the
top off and reveals a nut but what it does is a mystery to me.
- Pete & Sue
- Tribal Elder
Ralph, if you want cheap a throttle travel limiter, a bungee strap of the correct length, hooked on your belt, then on the first eyelet of your boot will restrict travel, if you wear 13 eyelet Doc Martens you can vary the tension to 13 speeds. I think I should sell these bongo speed controls on Ebay.
Shakey (Watch out for sudden acceleration, the rebound from kickdown could be a cheap form of contraception!!)
