Sump plug
samuel
Sump plug
Post by samuel » Tue Oct 02, 2007 8:13 pm
Just done oil change and sump plug and washer look a little the worse for wear! Refitted this time but me thinks next time a new one needs to go back.
Anyone know part no. or a comptible replacement?
"Living the Dream"
brorabongo
Post by brorabongo » Tue Oct 02, 2007 8:40 pm
I've been using ones I got for my previous car a fiat Ulysse 2.0l petrol. I did have a thread with pictures showing size but it's been deleted :cry:
Try using the search using....... sump AND plug
ボンゴの激怒 pictures
samuel
Post by samuel » Tue Oct 02, 2007 8:43 pm
Thanks Brora. I've noted where you live. I think i live closer to Italy than i do to you!!
"Living the Dream"
Post by missfixit70 » Tue Oct 02, 2007 11:10 pm
Ford ranger one from a ford dealer apparantly, will be checking this theory out in a week or two, will keep you informed , hopefully with a part number. Other option is to anneal it as mentioned a week or two ago on here somewhere. heat up to red hot with blowtorch & drop in cold water if i remember rightly? :?
brorabongo
Post by brorabongo » Tue Oct 02, 2007 11:33 pm
missfixit70 wrote:heat up to red hot with blowtorch & drop in cold water if i remember rightly? :?
Thats great for standard washers, The ones I use are crush washers, so that won't work. I don't know what the original washers are like as mine did not have a washer on it, when I did my first change :?
Others are using PTFE tape with good effect.
This might give you an idea of size:-
ボンゴの激怒 pictures
Simon Jones
Post by Simon Jones » Wed Oct 03, 2007 8:29 am
I've found even with a new washer that it can still leak slightly. I now put a smear of Blue Hylomar gasket compound on the threads & it works a treat. It also just peels off when it comes to change the oil again, so nice & easy.
roosteruk
Post by roosteruk » Wed Oct 03, 2007 10:22 am
You can't beat Hylomar.....Tried and tested by Roll Royce.
Demios
Post by Demios » Wed Oct 03, 2007 10:29 am
The washers are about 70p from bongobits
handyman
Post by handyman » Wed Oct 03, 2007 7:35 pm
You lot are very lucky. I cannot get the bloody plug out of the sump. :roll: so no chance of a leak.
My previous oil changes are sucked ( :P ) out of the dip stick hole. Some bloody mechanic possibly in Japan f**ked the plug up, i.e rounded the nut off so I have to sort someting out for the next service so I'm told.
Steve L
Post by Steve L » Wed Oct 03, 2007 7:59 pm
Buy a new plug and get the old one off with a stillson wrench, but I presume you knew that already being a handyman. :D
1995 N reg 2WD AFT in green/grey
www.whiteroseancestry.co.uk
