Dumb idea... or could I change my coolant like this?
Lewy
Right I know my coolant is a weak mix and want to change it. But dont want to drain out the whole system and have the worries of a poor bleed and re-fill so...
Could I extract the header tank fluid using my big oil change syringe and replace with good quality antifreeze and water mix. Then run the engine for a bit, stop and do it again top up again, run and circulate the fluid again, stop and...well you get the idea.
What do you reckon - good idea of complete idiotic ramblings?
roosteruk
shakey
I upgraded my antifreeze strength last year after a RAC man topped up and bled the system with clear water. I loosened the bottom rad hose and SLOWLY let out enough liquid to nearly empty the header, then filled it with neat antifreeze. I repeated this until the darker green colour was obviously being let out at the bottom, when I stopped. Ran engine and then tested antifreeze strength. All O.K. and has been for past 13 months. Cannot remember how much antifreeze I used though. A bit lazy, but it worked for me
Shakey.
roosteruk
- Muzorewa
You're not kidding....roosteruk wrote: ......Don't swallow....
http://news.bbc.co.uk/1/hi/england/west ... 701360.stm
Steve1259
Wow that’s scary Muzorewa,
Lewy,
You will need to watch the mixture strength of antifreeze to water, if you end up with anything over 65% antifreeze – 35% water then the mixture starts to lose its ability to absorb heat. This means that your cooling system will not be as effective. We all know that these cooling systems need all the help they can get!
Steve
Lewy,
Steve
Veg_Ian
- Muzorewa
As I recall from the time of the incident, in the absence of any other explanation the hospital presumed the guy had had a stroke and started treating him as such, with drugs to slow the metabolism - which apparently is the worst thing to do with a poisoning victim - hence the massive damage that was ultimately caused. I'm no medic but don't drink antifreeze!Steve1259 wrote:Wow that’s scary Muzorewa,
I still drink Perrier, though
- dandywarhol
I seem to remember the Austrians having a taste for it in the 80sMuzorewa wrote:As I recall from the time of the incident, in the absence of any other explanation the hospital presumed the guy had had a stroke and started treating him as such, with drugs to slow the metabolism - which apparently is the worst thing to do with a poisoning victim - hence the massive damage that was ultimately caused. I'm no medic but don't drink antifreeze!Steve1259 wrote:Wow that’s scary Muzorewa,
http://www.weimax.com/austria.htm
john and jue
Lewy
