Condensation
quinnw
Condensation
Post by quinnw » Tue Sep 18, 2007 7:24 pm
At night, water is condensing on the inside windows. Any idea on how to reduce / eliminate? Apart from leave a window open...
Bill
Rog
Post by Rog » Tue Sep 18, 2007 7:30 pm
If you use your aircon, that acts as a de humidifier and may help,
especialy if it is set to recirculate setting for some of the time.
Rog
flash
Post by flash » Wed Sep 19, 2007 1:24 pm
I assume you mean that you get condensation when you sleep in the bongo. Silver screens help to reduce the effect by removing the amout of cold surface. but the best thing is as you mention, leave the windows cracked open slightly.
Harry
Post by Harry » Wed Sep 19, 2007 5:25 pm
This is where flyscreens come in handy....Dave up North has a set for sale! :shock:
http://watcherswildlife.co.uk
Colin Lambert
Post by Colin Lambert » Wed Sep 19, 2007 6:18 pm
Mine condenses very heavily on its own without any help from me!! Luckily I have front window wind deflectors so I leave the windows open 3 inchesand this stops the problem.
AndAndDen
Post by AndAndDen » Wed Sep 19, 2007 6:45 pm
We have wind deflectors, so do the same as Colin, leave windows open slightly. Never have a problem with condensation. :)
Get a Life ,Get a Bongo. !!!
Matt&JoyBongling
Post by Matt&JoyBongling » Fri Sep 21, 2007 1:44 pm
There was a warning some time ago about condensation dripping down the inside of the windscreen and causing electrical problems. We use a tea-towel to catch water as it drips down.
Underground, Overground, Bongoling Free, the Bonglers of Bedford, common are we ...
jgk
Post by jgk » Fri Sep 21, 2007 5:14 pm
hi had this problem water was seeping in from the sun roof witch coused
a patch of damp in the roof of the car i had blocked drain holes in the sunroof
unblocked the holes and let the car dry out and have not had a proble since hope this helps
