what engine oil level do users recommend ? .. ive always been advised to run half way between low and full on the dipstick but the factsheet appears to suggest it should be full
cheers IZ
oil level
- haydn callow
Colin Lambert
Well, there can be a reason on some engines - though probably not a Bongo. Old BMW boxer (bike) engines tend to vary quite a lot in the level at which the oil wants to sit at. Fill them up to the maximum mark & some engines will sit there quite happily, others will quickly blow off all the "excess" oil until it sits at "their" level full. On my bike for instance, there is no point in filling up beyond 3/4, but once it's blown off any excess it will sit there for quite a time (these engines do burn oil off). Anyway, I think that this is probably a quirk of older air-cooled engines of this type, so I'd agree that you'd probably want to fill a Bongo to the maximum mark.
Rhod
Rhod
- dandywarhol
izzizm
