removing front bumper
Post by missfixit70 » Sun Sep 16, 2007 1:06 pm
Done a search, nothing came up ( yes I used AND), wondered if anyone has removed their front bumper, if so how difficult. I've noticed some surface rust starting on the metalwork around the radiators & behind the grilles & want to get in & sort it out while I'm messing about with rust converter, zinc spray & waxoil on the rest of the chassis. Cheers in advance
brorabongo
Post by brorabongo » Sun Sep 16, 2007 1:23 pm
WOW, you must of read my mind!! I been thinking about posting such a question for the same reason, plus I would like to add a chrome style mesh behind the bumper and grill.
ボンゴの激怒 pictures
You've Been Bongod
front bumper
Post by You've Been Bongod » Sun Sep 16, 2007 5:22 pm
hi missfixit70 & brorabongo there are about 8 or 9 bolts holding on front bumper when changed mine ( damaged ) took bout 30 mins that easy there are 2 bolts in recess by front number plate , one on stabilizing bar , a screw by the wing and as far as i remember your number plate
hope this helps
you've been bongod
