Start up and idle question
Lovejoy
Hopefully this is normal behaviour and not a sign of something going wrong:
When I start up Bongo for the first time in the morning and sit with it idling while I fiddle with radio, take a phone call, pick nose or whatever, it starts to misfire a bit and idle roughly and chucks some grey smoke out the back.
I'm talking about a 1-2 minute period.
As soon as I give it some throttle it clears and is fine and drives off smooth as anything.
If I start it up, put it straight into gear and set off within 30 secs to 1 minute, there is no problem at all.
It also only does it on the first start of the day, any other time it will sit and idle fine.
Is this normal ? Anyone else have it happen ? If it is a sign of a possible looming problem anyone know what it might be ?
- haydn callow
Lovejoy
Thanks. If it is just that it sounds like a cheap repair.
I had an escort van once which did a similar thing sometimes but did it as soon as it started - a real lumpy idle with a loud knocking and smoke from the back.
It usually cleared after switching it off and giving it a couple more bursts of heat to the plugs.
I cured it with a new battery and 4 new plugs in the end.
But this is different in that the engine fires first time the second the key is turned, and only starts getting lumpy if left to idle.
So I hadn't linked the two.
Thanks for the tip, i'll get some new plugs fitted anyway (or tested).
- brorabongo
Me?... Get my hands dirty?
That's a full set of four (longer version) Supplied and fitted.
The price is slightly approximate, I had my NICK SKIDMORE E.G.R. removal kit fitted at the same time,which took it to 3 hours labour altogether,the glowplugs are £24 per set,plus an hours labour (£10).
I wouldn't recommend just replacing the worn plugs, you have to remove them to test em!
Stick a new full set in,that way the weakest old plug isn't under too much strain.
Lovejoy
Thanks, I'll get Peter onto it before they start giving me starting problems in the Winter.bigdaddycain wrote:I had exactly the same problem a few weeks back lovejoy.
It turned out to be my glowplugs, although they all worked,two of them were "lazy".
£35 supplied and fitted
Nice to know that not all repairs are stupidly expensive
- haydn callow
Lovejoy
I'm sure it is, I'm on a roll at the moment.haydn callow wrote:If !!! Thats what it is !!!
Doom & Gloom
Fitted my new rear shocks this afternoon (finally, they've been sitting in the hall for weeks reminding me of a job that needed doing) without any hassles - procomp es9000's in white. £85 for the two including delivery - bargain. Thanks to being pointed in the right direction by some kind soul on this forum.
Also finally got around to looking at why my rear window wiper was not working, and that turned out to be simply a screw on my lower curtain rail which was shorting a cable. As soon as I took the screw out all was working again, so put a pop rivet in its place and all OK.
Oh, and my little Combo van passed its MoT in the week with no work needed - which surprised me on a 9 year old 156,000 mile well used van.
So I am touching wood that things are going my way at the moment. Shouldn't have said that should I
kawasaki kid
- Tribal Elder
prb007
prb007
prb007
