Help 2nd opinion needed - removing engine to change bolt....
FI 'N FREDA
Post by FI 'N FREDA » Wed Sep 12, 2007 12:49 pm
hi all - hanks to the wonderful techie forum and archives we correctly identified that our manifold stud had broken (the old screaming problem) and ordered the bits which have just come – but our garage (new to bongos but great so far) has said that the bolt has sheared inside the block and he cant get at it without removing the engine, which is sounding expensive – is this right and do people generally drop the engine or lift it (he’s trying to work it out but I thought I’d ask)???? Oh for a bongo friendly garage in North Birmingham!!
haydn callow
Post by haydn callow » Wed Sep 12, 2007 12:55 pm
Which bolt is it?? if the extream left one over the alternater then it is a very simple job that should take no more than 2 hours and not cost mote than £100. Just a case of drilling out and helicoiling. I would think the same would apply to any of the bolts but others may need a few more bits removing. It is normally the No 1 stud which you can see above and right of the alternator.
http://www.coolantalarm.co.uk
Also BMW Clocks
haydn callow
Post by haydn callow » Wed Sep 12, 2007 12:56 pm
Where are you. Anywhere near Somerset and my mate will do it for you. Did mine
Also BMW Clocks
haydn callow
Post by haydn callow » Wed Sep 12, 2007 12:58 pm
AH!! north Brum
Also BMW Clocks
haydn callow
Post by haydn callow » Wed Sep 12, 2007 1:00 pm
What bits?? with luck you will only need a bit of oversize stud.
Also BMW Clocks
Veg_Ian
Post by Veg_Ian » Wed Sep 12, 2007 1:02 pm
Removing the engine to replace a manifold bolt? Interesting practice for making huge profits. Unless access is that bad that you can't get tools in (and I'm pretty sure that's not the case with all the manifold bolts) then I'm afraid your mechanic is wrong or maybe he doesn't want the work. It's just as Haydn has outlined - drill out the old then fit helicoil with new bolt. All do-able with engine in situ.
FI 'N FREDA
Post by FI 'N FREDA » Wed Sep 12, 2007 1:08 pm
Many many thanks - I think I will remove freda and seek new garage!
dandywarhol
Post by dandywarhol » Wed Sep 12, 2007 6:10 pm
also.....the stud doesn't go into the "block" it goes into the head - change your garage! :shock:
